[fusion-users] invoke php query in Fusion
Zac Spitzer zac.spitzer at gmail.com
Wed Sep 24 10:26:00 EDT 2008
The PHP code most likely will barely change at all, you are just going
to need to
change your javascript a bit.
Can you describe exactly what your trying to do in terms of the map
interaction?
Are you using Mapguide Studio?
z
On Wed, Sep 24, 2008 at 1:26 AM, lolob <azzam_wahab at hotmail.com> wrote:
> Hello everyone,
> First of all thanks for reading this post..and I hope somebody would give
> some advice here..I would like to use the same code of PHP query which has
> been tested perfectly with Mapguide AJAX viewer basic layout and, I want to
> use it in Fusion(MGOSv2.02)..I've been using MGOSv1.2 and, I would like to
> upgrade to 2.02 version and use the fusion flexible layout..Can somebody at
> least give step by step, how ( preferably in code) to make the query works
> in Fusion.. Thanks!!
> -lolob
> View this message in context: http://www.nabble.com/invoke-php-query-in-Fusion-tp19630252p19630252.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the fusion-users mailing list
