[fusion-users] invoke php query in Fusion
lolob azzam_wahab at hotmail.com
Wed Sep 24 23:38:19 EDT 2008
Thanks for you attention! Currently, I'm using MGOS v1.2 and the query (as in
the image) works fine. Now I want to test the query inside the Flexible
Layout(Fusion) under MGOS v2.02. But it don't work, no error and a blank
page. I use example from phpviewersamples and learn from there. What parts
of javascript exactly in php code and could you explain a little bit.
http://www.nabble.com/file/p19662546/query.gif
Thanks
-lolob
zspitzer wrote:
> The PHP code most likely will barely change at all, you are just going
> to need to
> change your javascript a bit.
> Can you describe exactly what your trying to do in terms of the map
> interaction?
> Are you using Mapguide Studio?
> z
> On Wed, Sep 24, 2008 at 1:26 AM, lolob <azzam_wahab at hotmail.com> wrote:
>> Hello everyone,
>> First of all thanks for reading this post..and I hope somebody would give
>> some advice here..I would like to use the same code of PHP query which
>> has
>> been tested perfectly with Mapguide AJAX viewer basic layout and, I want
>> to
>> use it in Fusion(MGOSv2.02)..I've been using MGOSv1.2 and, I would like
>> to
>> upgrade to 2.02 version and use the fusion flexible layout..Can somebody
>> at
>> least give step by step, how ( preferably in code) to make the query
>> works
>> in Fusion.. Thanks!!
>> -lolob
>> View this message in context:
>> http://www.nabble.com/invoke-php-query-in-Fusion-tp19630252p19630252.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/invoke-php-query-in-Fusion-tp19630252p19662546.html
More information about the fusion-users mailing list
