[fusion-users] Fusion 2 - Google & Sheboygan Sample
Berdel, Brian brian.berdel at mcmtrans.com
Wed Apr 1 12:53:27 EDT 2009
Thanks for the replies.  Those coordinate systems are not accessible in Mapguide 2.0.2
Maybe 2.1?
-Brian
-----Original Message-----
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of percy
Sent: Wednesday, April 01, 2009 10:07 AM
Cc: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] Fusion 2 - Google & Sheboygan Sample
You have to use Spherical Mercator EPSG:900913 (google in L33T) or
EPSG:3785, but I don't know how to specify that in mapguide, just in
mapserver :-)
Does mapguide reproject on-the-fly?
Percy
Paul Spencer wrote:
> Google and all the other commercial services are not in EPSG:4326 (WGS84
> LatLong), rather they use a spherical mercator projection.  I'm not sure
> how to configure this in MapGuide.
> On 31-Mar-09, at 5:00 PM, Berdel, Brian wrote:
>> Thanks Mike, that actually did work to get them both on.  However I
>> have to zoom in to Sheboygan then turn the layers on and off to get
>> them to appear.
>> These are the problems I have noticed:
>> 1. I cannot set the correct extents...The map always starts with a
>> full view of the world...Shouldn't it get set to the extents of my
>> first map?
>>     I tried setting it with ( as in example)
>>         <maxExtent>-87.764986990962839,- 87.695521510899724,
>> 43.691398128787782, 43.797520000480347</maxExtent>
>>     I noticed in Generic.js that there is a comment saying:
>>     this.mapTag.layerOptions.maxExtent = null;    //maxExtent not
>> allowed on Google layers
>>     So it looks as though this is not correct...
>> 2. Once viewable, the maps do not overlay properly even though they
>> are both the same coordinate system WGS84.
>>     I tried with Sheboygan and some other data I have in WGS84.
>> 3. You cannot set the maps background color to transparent in studio /
>> maestro / or XML (not that I know of anyway)
>>     So, there will always be a color blocking the underlying google
>> map if any layer from the top map is on
>>     This also goes for any maps you may try to overlay
>> Thanks,
>> Brian
>> From: Mike Adair [mailto:madair at dmsolutions.ca]
>> Sent: Tuesday, March 31, 2009 4:09 PM
>> To: Berdel, Brian
>> Can you try putting a
>> <Options><isBaseLayer>false</isBaseLayer></Options> in your MapGuide
>> layer <Extension> element. OL only allows one baselayer at a time and I
>> suspect the MG layer gets set as a baselayer.
>> Mike
>>> Hello,
>>> I have been trying to test the functionality of adding google maps to
>>> the Sheboygan Sample Map in my Appdef but have had no luck...I am able
>>> to get google to show up but the Sheboygan data does not. I can see
>>> the Sheboygan layers in the legend but when I zoom to sheyboygan the
>>> overview map does show that I am in the correct location but there are
>>> no layers in the map. Here is my AppDef. I have tried using the
>>> Tiledmap and regular and setting singletile & isbaselayer to true /
>>> false. Am I not doing something right? Sheboygan is the same
>>> coordinate system as Google.
>>> <MapGroup id="sheboygan" xsi:type="MapType">
>>> <Map xsi:type="MapGuideLayerType">
>>> <Type>MapGuide</Type>
>>> <SingleTile>true</SingleTile>
>>> <Extension>
>>> <ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</ResourceId>
>>> <SelectionAsOverlay>true</SelectionAsOverlay>
>>> <SelectionFormat>PNG</SelectionFormat>
>>> <SelectionColor>0xFF0000FF</SelectionColor>
>>> </Extension>
>>> </Map>
>>> <Map xsi:type="WMSLayerType">
>>> <Type>Google</Type>
>>> <Extension>
>>> <ResourceId>google</ResourceId>
>>> <Options>
>>> <name>GoogleLayer</name>
>>> <type>G_PHYSICAL_MAP</type>
>>> <isBaseLayer>true</isBaseLayer>
>>> <sphericalMercator>false</sphericalMercator>
>>> </Options>
>>> </Extension>
>>> </Map>
>>> </MapGroup>
>>> Brian Berdel
>>> Applications Development Manager
>>> McMahon Associates, Inc.
>>> 425 Commerce Drive, Suite 200
>>> Fort Washington, Pennsylvania 19034
>>> p: 215.283.9444 x 260
>>> f: 215.283.9858
>>> http://www.mcmtrans.com/mcm_logo.jpg <http://www.mcmtrans.com/>
>>> New England | Mid-Atlantic | Florida
>>> fusion-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>   Michael Adair
>>   Senior Software Architect
>>   DM Solutions Group Inc.
>>   Office: (613) 565-5056 x26
>>   http://www.dmsolutions.ca
>>   http://research.dmsolutions.ca
>    Paul Spencer
>    Chief Technology Officer
>    http://research.dmsolutions.ca/
David Percy
Geospatial Data Manager
Geology Department
Portland State University
http://gisgeek.pdx.edu
503-725-3373
More information about the fusion-users mailing list
