[fusion-users] Changing Session-based maps in Fusion
Paul Spencer pspencer at dmsolutions.ca
Fri Aug 28 19:38:05 EDT 2009
Sounds like something could be done but I'm not sure I follow the
logic of what needs to be done.  Is it possible for you to elaborate a
little more?
On 2009-08-24, at 6:10 AM, Bill Ten Broeck wrote:
> Hello.
> We have an application that has a navigation tool that allows the
> user to select a site (each site has its own, pre-defined map), and
> then drill down into the site. The drilldown-map is basically an
> empty, arbitrary coordinate system template map, which we erase then
> add layers to depending on what they have selected. We have this
> working well, provided we start with, or expose the template map,
> and then create our session based map. (IE, it has to be the
> currently visible map). What we need to be able to do is go directly
> from the static map to the runtime map with no intermediate step of
> needlessly exposing the template, just to make it the current map.
> It seems like the approach we are looking for is to change the
> session map in fusion to a session map we have created server side
> but we aren’t quite sure how to approach this. Is this clear? And if
> so, would anyone be willing to sketch out an approach?
> Thanks in advance.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the fusion-users mailing list
