[fusion-users] How to pass a parameter from URL
Paul Deschamps pdeschamps at dmsolutions.ca
Wed Feb 18 09:19:26 EST 2009
Hi jsanchez,
There are a few different ways you can accomplish this. I would recommend
that you create a separate php script and call it on the fusion.onInitialize
Here's some sample code. It may be a little rough and need a little TLC as I
just whipped it together for you.
window.onload = function() {
    Fusion.initialize();
    Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, onInitialize);
function onInitialize(){
    // create a queryString object
    var oQS = new queryString();
    // get the QS "layers"
    var gLayers = oQS.get("layers");
    // get the mapwidget
    var mapWidget = Fusion.getMapById('mapArea');
    var maps = mapWidget.getAllMaps();
    var map = maps[0];
    // set the parameters for sessionid and mapname and layers
    var session = 'session='+map.getSessionID();
    var mapName = '&mapname='+ map._sMapname;
    var layers = '&layers='+gLayers;
    var params = session+mapName
    // bind ajax call to the function reloadMap
    var opts = {parameters: params, onComplete: reloadMap.bind(null)};
    var s =  "../myApp/showLayers.php";
    // trigger the ajax call
    Fusion.ajaxRequest(s, opts);
function reloadMap(){
    var map = Fusion.getMapById('mapArea');
    var maps = map.getAllMaps();
    maps[0].reloadMap();
function queryString(qs){
    d.log("queryString");
    this.params = {};
    this.get=queryString_get;
    if (qs == null)
        qs=location.search.substring(1,location.search.length);
    if (qs.length == 0) return;
    qs = qs.replace(/\+/g, ' ');
    var args = qs.split('&');
// split out each name=value pair
    for (var i=0;i<args.length;i++) {
        var value;
        var pair = args[i].split('=');
        var name = unescape(pair[0]);
        if (pair.length == 2)
            value = unescape(pair[1]);
        else
            value = name;
        this.params[name] = value;
function queryString_get - return the key values
function queryString_get(key, default_) {
    // This silly looking line changes UNDEFINED to NULL
    if (default_ == null) default_ = null;
    var value=this.params[key];
    if (value==null) value=default_;
    return value;
On Wed, Feb 18, 2009 at 5:18 AM, jsanchez <ebarrera at inm.es> wrote:
> Hello all,
> I'm just testing 'Fusion' and I wonder if it would be possible to deal with
> dynamic layers.
> I would like the user could choose the data shown in a fixed given layer.
> To
> do so, I don't define the layer it on my MapServer/MAPFILE but instead I
> create it during Fusion load proccess using Mapscript in LoadMap.php which
> works fine.
> Now I'd like to know how to pass a parameter from URL application to
> LoadMap.php containing the 'data' layer parameter which points to desired
> raster file.
> Thanks
> http://n2.nabble.com/How-to-pass-a-parameter-from-URL-tp2346032p2346032.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
   Paul Deschamps
   Applications Specialist
   DM Solutions Group Inc.
   Office: (613) 565-5056 x28
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090218/77f669c9/attachment.html
More information about the fusion-users mailing list
