[fusion-users] Setting the selection in the map to a specified
	polygon in a layer
    Mike Adair
    madair at dmsolutions.ca
    Wed Jan 14 13:12:41 EST 2009
Ari,
I can't recall where I got this from but this is an example I have used
for testing:
  var xml = '<?xml version="1.0" encoding="UTF-8"?>';
  xml += '<FeatureSet
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd">';
  xml += '<Layer id="'+layer.uniqueId+'">';
  xml += '<Class id="SHP_Schema:Parcels"><ID>MSYAAA==</ID></Class>';
  xml += '</Layer></FeatureSet>';
In this case the <Class> element is for the Sheboygan dataset.
Mike
Ari Þórðarson wrote:
> Hi everyone
> I have a map of a town with many houses wich are all in one layer and
> each house has an id and I want to set the selection to one house with
> a specified id.  I thought that I could maby use the "setSelection"
> function in Map.js that is like this:
> setSelection: function(selText, zoomTo)
> Does anyone know in what kind of format the selText parameter for the
> setSelection function is suposed to be in.
> It would be nice if I could se an example string that is passed to the
> function.
> Greetings, Ari
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
More information about the fusion-users
