[fusion-users] Groups are shown again as Layers
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Mon Jun 15 14:30:25 EDT 2009
Bernhard,
This is what you need to remove the Map folder from your legend:
ApplicationDefinition.xml:
		<!-- LEGEND -->
		<Widget xsi:type="WidgetType">
			<Name>Legend</Name>
			<Type>Legend</Type>
			<StatusText/>
			<Extension xsi:type="CustomContentType">
<HideInvisibleLayers>true</HideInvisibleLayers>
				<ShowRootFolder>false</ShowRootFolder>
				<ShowMapFolder>false</ShowMapFolder>
				<GroupInfoIcon/>
			</Extension>
		</Widget>
Specifically '<ShowMapFolder>' is what you are after.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
[mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Bernhard
Schneider
Sent: Monday, June 15, 2009 1:34 PM
To: fusion-users at lists.osgeo.org
Subject: [fusion-users] Groups are shown again as Layers
Problem solved:
The map file I use had a LAYER defined for each group. I deleted these
layers and moved the METADATA information to the first LAYER belonging
to the group, as described in the MapServer HowTo on configuring legend
and layer behaviour.
Still trying to figure out how to remove the Map folder in the legend
tree though.
Bernhard
More information about the fusion-users mailing list
