[fusion-users] RE: Fusion 2.0/MapServer & Units
Berdel, Brian brian.berdel at mcmtrans.com
Wed Jun 24 13:35:11 EDT 2009
I did not experience your exact situation, but I tested with Mapguide and the measure tool is not working properly for me either.
Beta Version cannot display Feet Correctly, and the SVN version gives me a precision error and does not really work at all in IE7 or 8. In Firefox seems to work but the values for feet are way off. Thanks.
Brian
-----Original Message-----
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Nolte, Tim
Sent: Wednesday, June 24, 2009 1:27 PM
To: fusion-users at lists.osgeo.org
Subject: [fusion-users] Fusion 2.0/MapServer & Units
So here is my dilemma. I've tried to find the source of it and it seems
like this is a core Fusion code issue. My MapServer mapfile has it's
units set in decimal degrees (DD) with an extent set in those units. It
would seem that this mapfile setting completely overrides anything I put
in my ApplicationDefinition.xml for Units or DisplayUnits. I want the
cursor coordinates displayed in DD and I want the measure tool and the
view size status to be in miles. Has anyone got a clue how to get this
to work. I was able to change my mapfile UNITS set to MILES but this
really doesn't fix my map as 1) I don't know what to set for my map
EXTENTS and 2) then the cursor is in miles instead of DD. I'm probably
not going to let the measuring issue be a complete show stopper but the
is a tool that we already have in our Chameleon application that I think
people are already using. Thanks.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
More information about the fusion-users mailing list
