[fusion-users] Adding two or more maps
Chris Claydon chris.claydon at autodesk.com
Wed Mar 18 10:22:27 EDT 2009
It would be my guess that Fusion doesn't pick up the extents of the new map. If you use the same coordinate system and extents for the two maps, does it work?
-----Original Message-----
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of wood77
Sent: Wednesday, March 18, 2009 3:27 AM
To: fusion-users at lists.osgeo.org
Subject: RE: [fusion-users] Adding two or more maps
Hi Chris, thank you for the reply.
 In Fusion 2.0 I get the MapGroup like below,
<?xml version="1.0" encoding="utf-8"?>
<MapSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <MapGroupType id="Osaka">
    <Map>
      <Type>MapGuide</Type>
      <SingleTile>true</SingleTile>
      <Extension>
<ResourceId>Library://Buildings/Osaka/Maps/MapO.MapDefinition</ResourceId>
      </Extension>
    </Map>
    <Extension />
  </MapGroupType>
  <MapGroupType id="Music">
    <Map>
      <Extension>
<ResourceId>Library://Buildings/Music/Maps/MapM.MapDefinition</ResourceId>
      </Extension>
    </Map>
    <Extension />
  </MapGroupType>
  </MapSet>
I can select the maps in map menu, but it wont load the map.I can even get
the Legend panel for the selected map, but not the map.
Thanks.
Chris Claydon wrote:
> When you edit the MapGroup XML with Fusion 2.0, what do you get in the map
> menu?
> Sent: Tuesday, March 17, 2009 5:05 AM
> Subject: [fusion-users] Adding two or more maps
> Hi All,
>  How to I add two or more maps to the Map menu. I was able to do that with
> MGOS 2.0.0 with fusion 1.1 by editing MapGroup XML. But with MGOS 2.0.2
> and
> Fusion 2.0 it wont work properly.
> Thanks.
> http://n2.nabble.com/Adding-two-or-more-maps-tp2490702p2490702.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
View this message in context: http://n2.nabble.com/Adding-two-or-more-maps-tp2490702p2496114.html
More information about the fusion-users mailing list
