[fusion-users] Adding two or more maps
Mike Adair madair at dmsolutions.ca
Wed Mar 18 10:04:44 EDT 2009
Looks like a bug in MapMenu.  I've created a ticket for this:
http://trac.osgeo.org/fusion/ticket/228
Mike
wood77 wrote:
> Hi Chris, thank you for the reply.
>  In Fusion 2.0 I get the MapGroup like below,
> <?xml version="1.0" encoding="utf-8"?>
> <MapSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema">
>   <MapGroupType id="Osaka">
>     <Map>
>       <Type>MapGuide</Type>
>       <SingleTile>true</SingleTile>
>       <Extension>
> <ResourceId>Library://Buildings/Osaka/Maps/MapO.MapDefinition</ResourceId>
>       </Extension>
>     </Map>
>     <Extension />
>   </MapGroupType>
>   <MapGroupType id="Music">
>     <Map>
>       <Extension>
> <ResourceId>Library://Buildings/Music/Maps/MapM.MapDefinition</ResourceId>
>       </Extension>
>     </Map>
>     <Extension />
>   </MapGroupType>
>   </MapSet>
> I can select the maps in map menu, but it wont load the map.I can even get
> the Legend panel for the selected map, but not the map.
> Thanks.
> Chris Claydon wrote:
>> When you edit the MapGroup XML with Fusion 2.0, what do you get in the map
>> menu?
>> -----Original Message-----
>> From: fusion-users-bounces at lists.osgeo.org
>> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of wood77
>> Sent: Tuesday, March 17, 2009 5:05 AM
>> To: fusion-users at lists.osgeo.org
>> Subject: [fusion-users] Adding two or more maps
>> Hi All,
>>  How to I add two or more maps to the Map menu. I was able to do that with
>> MGOS 2.0.0 with fusion 1.1 by editing MapGroup XML. But with MGOS 2.0.2
>> and
>> Fusion 2.0 it wont work properly.
>> Thanks.
>> View this message in context:
>> http://n2.nabble.com/Adding-two-or-more-maps-tp2490702p2490702.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
More information about the fusion-users mailing list
