[fusion-users] Problems with fusion. Maps disappears
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Mon Oct 5 10:13:24 EDT 2009
This is a bug that exists in the Fusion MapServer PHP code. The in the
file layers\MapServer\php\Query.php it is hard-coded to look for
"query.qry" however MapServer's query file is created as "query.qy". If
you edit around line 81 and change the "qry" to "qy" this should fix
your problem. Also, in order to see this reflected on the map visually
be sure to have the "QUERYMAP" section of your mapfile defined.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
[mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of jbogdani
Sent: Saturday, October 03, 2009 9:25 AM
To: fusion-users at lists.osgeo.org
Subject: [fusion-users] Problems with fusion. Maps disappears
Hello all,
I'm new to fusion and I' trying to handle some shapefiles and raster
data to
manage a simple webGIS viewer.
I'm running mapserver (latest) and fusion on a Linux Ubuntu Server
edition.
My problem is that when I run in select mode I have my attributes
regularly
showed on the selection panel on the left, but the map disappears.
You can have a look here:
http://webgis.dyndns.info/fusion/templates/mapserver/standard2/
View this message in context:
http://n2.nabble.com/Problems-with-fusion-Maps-disappears-tp3760203p3760
203.html
Sent from the Fusion Users mailing list archive at Nabble.com.
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
