[fusion-users] Problems with fusion. Maps disappears
Mike Adair madair at dmsolutions.ca
Mon Oct 5 10:30:35 EDT 2009
And this was fixed in trunk last week.
http://trac.osgeo.org/fusion/ticket/246
Mike
Nolte, Tim wrote:
> This is a bug that exists in the Fusion MapServer PHP code. The in the
> file layers\MapServer\php\Query.php it is hard-coded to look for
> "query.qry" however MapServer's query file is created as "query.qy". If
> you edit around line 81 and change the "qry" to "qy" this should fix
> your problem. Also, in order to see this reflected on the map visually
> be sure to have the "QUERYMAP" section of your mapfile defined.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS:    616-706-2438
> Fax:    616-554-6484
> Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: fusion-users-bounces at lists.osgeo.org
> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of jbogdani
> Sent: Saturday, October 03, 2009 9:25 AM
> To: fusion-users at lists.osgeo.org
> Subject: [fusion-users] Problems with fusion. Maps disappears
> Hello all,
> I'm new to fusion and I' trying to handle some shapefiles and raster
> data to
> manage a simple webGIS viewer.
> I'm running mapserver (latest) and fusion on a Linux Ubuntu Server
> edition.
> My problem is that when I run in select mode I have my attributes
> regularly
> showed on the selection panel on the left, but the map disappears.
> You can have a look here:
> http://webgis.dyndns.info/fusion/templates/mapserver/standard2/
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
More information about the fusion-users mailing list
