[fusion-users] Problems with fusion. Maps disappears
jbogdani jbogdani at gmail.com
Mon Oct 5 11:25:11 EDT 2009
Mike Adair wrote:
> And this was fixed in trunk last week.
> http://trac.osgeo.org/fusion/ticket/246
> Mike
> Nolte, Tim wrote:
>> This is a bug that exists in the Fusion MapServer PHP code. The in the
>> file layers\MapServer\php\Query.php it is hard-coded to look for
>> "query.qry" however MapServer's query file is created as "query.qy". If
>> you edit around line 81 and change the "qry" to "qy" this should fix
>> your problem. Also, in order to see this reflected on the map visually
>> be sure to have the "QUERYMAP" section of your mapfile defined.
>> - Tim
>> Timothy J Nolte - tnolte at ilpcs.com
>> Network Planning Engineer
>> iPCS Wireless, Inc.
>> 4717 Broadmoor Ave, Suite G
>> Kentwood, MI 49512
>> Office: 616-656-5163
>> PCS:    616-706-2438
>> Fax:    616-554-6484
>> Web: www.ipcswirelessinc.com
>> -----Original Message-----
>> From: fusion-users-bounces at lists.osgeo.org
>> [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of jbogdani
>> Sent: Saturday, October 03, 2009 9:25 AM
>> To: fusion-users at lists.osgeo.org
>> Subject: [fusion-users] Problems with fusion. Maps disappears
>> Hello all,
>> I'm new to fusion and I' trying to handle some shapefiles and raster
>> data to
>> manage a simple webGIS viewer.
>> I'm running mapserver (latest) and fusion on a Linux Ubuntu Server
>> edition.
>> My problem is that when I run in select mode I have my attributes
>> regularly
>> showed on the selection panel on the left, but the map disappears.
>> You can have a look here:
>> http://webgis.dyndns.info/fusion/templates/mapserver/standard2/
>    Michael Adair
>    Senior Software Architect
>    DM Solutions Group Inc.
>    Office: (613) 565-5056 x26
>    madair at dmsolutions.ca
>    http://www.dmsolutions.ca
>    http://research.dmsolutions.ca
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Thank you all very much.
It works now, wonderfully!
Thanks again
View this message in context: http://n2.nabble.com/Problems-with-fusion-Maps-disappears-tp3760203p3769530.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
