[fusion-users] MapServer Transparent PNG Layers
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Fri Oct 23 15:59:52 EDT 2009
I'm attempting to user multiple MapServer maps using transparent PNGs so
that the end-user perception is that things load much faster. I'm
running into two problems:
1.) The 4 defined maps are not stacking correctly, getting my last map
(points.map) underneath one of the others (us_streets.map). But what is
interesting is that this behavior is not consistent, sometimes they are
in the right order but sometimes they are not.
		<MapGroup id="mapserver" xsi:type="MapType">
			<Map xsi:type="MapLayerType">
				<Type>MapServer</Type>
				<SingleTile>true</SingleTile>
				<Extension xsi:type="CustomContentType">
<MapFile>/export/home/www/ipcs/map/basemap.map</MapFile>
					<Options>
<isBaseLayer>true</isBaseLayer>
					</Options>
				</Extension>
			</Map>
<MapFile>/export/home/www/ipcs/map/regions.map</MapFile>
					<Options>
<isBaseLayer>false</isBaseLayer>
					</Options>
				</Extension>
			</Map>
<MapFile>/export/home/www/ipcs/map/us_streets.map</MapFile>
					<Options>
					</Options>
				</Extension>
			</Map>
<MapFile>/export/home/www/ipcs/map/points.map</MapFile>
					<Options>
					</Options>
				</Extension>
			</Map>
		</MapGroup>
		<MapWidget xsi:type="WidgetType">
			<Name>Map</Name>
			<Type>Map</Type>
			<StatusText>The map.</StatusText>
<MenuContainer>MapContextMenu</MenuContainer>
			</Extension>
			<MapId>mapserver</MapId>
		</MapWidget>
2.) When I try the above map setup the Legend sort of breaks. I have to
set ShowMapFolder to 'true' in order to even get something more then
just the first group of the base layer to show up in the Legend. Also
most of the individual layers with their legend symbols show up, with
the exception of the few layers that I have condition CLASSes on. I'm
attaching 2 screen shots as examples. Does anyone have any ideas how to
fix this?
		<Widget xsi:type="WidgetType">
			<Name>Legend</Name>
			<Type>Legend</Type>
			<StatusText/>
<HideInvisibleLayers>true</HideInvisibleLayers>
				<ShowRootFolder>false</ShowRootFolder>
				<ShowMapFolder>true</ShowMapFolder>
				<GroupInfoIcon/>
			</Extension>
		</Widget>
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
Type: image/png
Desc: ShowMapFolder_false.png
Url : http://lists.osgeo.org/pipermail/fusion-users/attachments/20091023/e7f4d192/ShowMapFolder_false-0001.png
Type: image/png
Desc: ShowMapFolder_true.png
Url : http://lists.osgeo.org/pipermail/fusion-users/attachments/20091023/e7f4d192/ShowMapFolder_true-0001.png
More information about the fusion-users mailing list
