[fusion-users] Get the Scale of the map
Paul Spencer pspencer at dmsolutions.ca
Thu Oct 22 13:07:15 EDT 2009
Yes, you could do that or you can just use it in your code whereever
you need the scale.
Cheers
Paul
On 2009-10-22, at 1:02 PM, Shekers wrote:
> Thanks a lot Paul,
> I'll try that out. I've actually thought of a way to do it before your
> reply.
> Since Fusion has the Editable Scale on the Status Bar, i just use some
> javascripts to get the value from the editable scale to get the
> scale. But
> your method would be more permanent.
> I assume I would put that in the MapGuideViewer.js as a function?
> Thanks
> Calvin Shek
> Paul Spencer-2 wrote:
>> Assuming that your map widget's *name* is Map,
>> Fusion.getWidgetById('Map').getScale();
>> Cheers
>> Paul
>> On 2009-10-21, at 11:32 PM, Shekers wrote:
>>> I was wondering if there's a way to get the scale of the map. I know
>>> there's
>>> GetScale() for the Ajax Viewer, but for the fusion viewer, there
>>> doesn't
>>> seem to be such function.
>>> View this message in context:
>>> http://n2.nabble.com/Get-the-Scale-of-the-map-tp3870023p3870023.html
>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>> fusion-users mailing list
>>> fusion-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>    Paul Spencer
>>    Chief Technology Officer
>>    DM Solutions Group Inc
>>    http://research.dmsolutions.ca/
> View this message in context: http://n2.nabble.com/Get-the-Scale-of-the-map-tp3870023p3873598.html
    Paul Spencer
More information about the fusion-users mailing list
