[fusion-users] Map Name as a parameter for FUSION
Mike Adair madair at dmsolutions.ca
Wed Feb 3 11:36:04 EST 2010
Rodolfo,
Fusion currently doesn't support that but I suspect it wouldn't be too
hard to do, as long as the session Id was also passed along since
LoadMap.php supports mapname+session as inputs (instead of
mapdefinition).   There may be issues  about keeping the session alive
in the new browser window.
Mike
Rodolfo Moreno wrote:
> Hi all, I know that a map definition can be passed as parameter in fusion
> viewer(theme parameter). However in my case I would prefer to pass the
> mapname as parameter. Is it possible?
> my use case is the following:
> - I have a site with many pages. The user enter to the page where the fusion
> viewer is loaded by default, it means without parameters. thus fusion
> creates the map object (based on the mapdefinition of the appDefinition.xml)
> and creates the map name too.
> - Next the user could create other session layers through the task pane by
> doing theming.
> - Followed the user could go to other page and next come back to the page
> where the fusion viewer is. In this moment the user should see the map such
> as he/she left it. In this case it wuold be better load the fusion viewer
> with the mapname as a parameter for both things: first because with the
> mapname we can obtain the map with all modifications that the user did (e.g.
> add layers) and second because we would avoid to create another map object
> and hence we would consume less resources.
> Regards,
> Rodolfo Moreno
> CivilEng
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
More information about the fusion-users mailing list
