[fusion-users] Re: Map Name as a parameter for FUSION
Rodolfo Moreno rodolfoamoreno at gmail.com
Wed Feb 3 14:49:14 EST 2010
Hi Mike, could you give me some clue about where I can modify?
It is what I was thinking about your idea:
- Add mapname parameter at the begining (e.g.
index.html?session=mySessionId&mapname=myMapname)
- Inside of fusion.js capture the mapname parameter and send it to
loadMap.php script
I have been reviewing the fusion.js but I haven't found the right place
where it call to the loadmap.php. Also I reviewed the map.js with the same
aim but with no success.
thanks in advance,
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Map-Name-as-a-parameter-for-FUSION-tp4507840p4509375.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
