[fusion-users] Fwd: MapGroup issue
Zac Spitzer
zac.spitzer at gmail.com
Tue Jan 11 01:38:26 EST 2011
reposted as the attachments were over 40k, so the message got flagged
for moderation
http://mapguide-central.ennoble.com.au/testcase/screenshots/overlap_lagging_and_not_updating.jpg
http://mapguide-central.ennoble.com.au/testcase/screenshots/overlap_lagging_and_not_updating_sheboygan.jpg
in the sheboygan test i did, I made a dynamic map with only
parcels and buildings, over a tiled map without those layers.
Something else i noticed is only the building layer would toggle on
and off, I wasn't able to get the parcels to even show
---------- Forwarded message ----------
Date: Tue, Jan 11, 2011 at 5:20 PM
Subject: MapGroup issue
To: fusion-users <fusion-users at lists.osgeo.org>
I'm using Mapguide 2.2 RC2 on windows
I am trying to combine a tiled map with a dynamic overlay,
both the map definitions are in the same projection, from the same
mapguide server
The problem I am having is when I zoom or pan, the dynamic layer just isn't
updating, the app layer doesn't come on until i toggle it off and then
on again and
then it is not updated, it gets stuck as per attached screenshots
I'm using the standard mapguide template applicationDefinition with
this as a mapgroup
<MapGroup id="app">
<Map>
<Type>MapGuide</Type>
<SingleTile>false</SingleTile>
<Extension>
<ResourceId>Library://base.MapDefinition</ResourceId>
</Extension>
</Map>
<Map>
<SingleTile>true</SingleTile>
<Extension>
<ResourceId>Library://app.MapDefinition</ResourceId>
</Extension>
<Options>
<isBaseLayer>false</isBaseLayer>
<useOverlay>true</useOverlay>
</Options>
</Map>
</MapGroup>
I tried this with our good old friend the sheboygan sample and had the
same issue.
any ideas?
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the fusion-users
