[fusion-users] Re: MapGroup issue
Zac Spitzer
zac.spitzer at gmail.com
Tue Jan 11 05:54:20 EST 2011
the parcels issue is not fusion related, it's a FDO issue in mapguide 2.2
On Tue, Jan 11, 2011 at 5:38 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> reposted as the attachments were over 40k, so the message got flagged
> for moderation
> http://mapguide-central.ennoble.com.au/testcase/screenshots/overlap_lagging_and_not_updating.jpg
> http://mapguide-central.ennoble.com.au/testcase/screenshots/overlap_lagging_and_not_updating_sheboygan.jpg
> in the sheboygan test i did, I made a dynamic map with only
> parcels and buildings, over a tiled map without those layers.
> Something else i noticed is only the building layer would toggle on
> and off, I wasn't able to get the parcels to even show
> ---------- Forwarded message ----------
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Date: Tue, Jan 11, 2011 at 5:20 PM
> Subject: MapGroup issue
> To: fusion-users <fusion-users at lists.osgeo.org>
> I'm using Mapguide 2.2 RC2 on windows
> I am trying to combine a tiled map with a dynamic overlay,
> both the map definitions are in the same projection, from the same
> mapguide server
> The problem I am having is when I zoom or pan, the dynamic layer just isn't
> updating, the app layer doesn't come on until i toggle it off and then
> on again and
> then it is not updated, it gets stuck as per attached screenshots
> I'm using the standard mapguide template applicationDefinition with
> this as a mapgroup
> <MapGroup id="app">
> <Map>
> <Type>MapGuide</Type>
> <SingleTile>false</SingleTile>
> <Extension>
> <ResourceId>Library://base.MapDefinition</ResourceId>
> </Extension>
> </Map>
> <Map>
> <SingleTile>true</SingleTile>
> <Extension>
> <ResourceId>Library://app.MapDefinition</ResourceId>
> </Extension>
> <Options>
> <isBaseLayer>false</isBaseLayer>
> <useOverlay>true</useOverlay>
> </Options>
> </Map>
> </MapGroup>
> I tried this with our good old friend the sheboygan sample and had the
> same issue.
> any ideas?
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the fusion-users
