[fusion-users] blank screen in fusion
Rachot Moragraan moo at ci.garden-grove.ca.us
Fri Feb 10 11:26:51 EST 2012
You usually have to specify the ApplicationDefinition parameter to the template:
http://localhost/fusion/templates/mapserver/standard/index.html?ApplicationDefinition=Library://Layouts/Foobar.ApplicationDefinition
if you dont, it's gonna try to render the default definition which is the Sheboygan example. If you're seeing blank, it's probably that you dont have Sheboygan example installed.
See here for the Sheboygan example:
http://mapguide.osgeo.org/download/releases/2.0.x-samples
hope that helps!
----- Original Message -----
To: fusion-users at lists.osgeo.org
Sent: Friday, February 10, 2012 8:25:13 AM
Subject: [fusion-users] blank screen in fusion
dear all
I'm new member in this mailing list. I have a problem when i installed
fusion in windows 7. Once i finished the installation procedure, when
i open web address of fusion at
http://localhost/fusion/templates/mapserver/standard/index.html, the
blank screen was viewed in my browser. The snapshot of my screen is
attached in this email.
Is there anybody can help me to solve this problem ? please
regards
Firdaus
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
