[fusion-users] blank screen in fusion
Rachot Moragraan
moo at ci.garden-grove.ca.us
Fri Feb 10 19:36:09 EST 2012
Put the Sheboygan.mgp in your package folder (probably something like: C:/Program Files/Autodesk/MapGuideEnterprise2011/Server/Packages/). you can configure that folder in the admin page.
visit the admin page (probably http://localhost/mapguide/mapadmin/login.php). go to "Manange Pacakges". You should now see your Sheboygan there. Select it and load the file and that should be it!
Not sure what you mean with the ApplicationDefinition.xml. But if you look under the standard template direction, you'll see the XML there specifying Sheboygan as the default path.
Also, please do a reply all to include the mailing list. Hopefully others with expertise will be able to help further.
----- Original Message -----
To: "Rachot Moragraan" <moo at ci.garden-grove.ca.us>
Sent: Friday, February 10, 2012 3:32:07 PM
Subject: Re: [fusion-users] blank screen in fusion
thanks so much for your help.
I've download Sheboygan.mgp from website, but i don't know how to put
it in the web directory and how to obtain it in the
Please guide me how to work on it.
Best Regards
On Fri, Feb 10, 2012 at 5:26 PM, Rachot Moragraan
<moo at ci.garden-grove.ca.us> wrote:
> You usually have to specify the ApplicationDefinition parameter to the template:
> http://localhost/fusion/templates/mapserver/standard/index.html?ApplicationDefinition=Library://Layouts/Foobar.ApplicationDefinition
> if you dont, it's gonna try to render the default definition which is the Sheboygan example. If you're seeing blank, it's probably that you dont have Sheboygan example installed.
> See here for the Sheboygan example:
> http://mapguide.osgeo.org/download/releases/2.0.x-samples
> hope that helps!
> From: "Firdaus firdaus" <alikomeini at gmail.com>
> To: fusion-users at lists.osgeo.org
> Sent: Friday, February 10, 2012 8:25:13 AM
> Subject: [fusion-users] blank screen in fusion
> dear all
> I'm new member in this mailing list. I have a problem when i installed
> fusion in windows 7. Once i finished the installation procedure, when
> i open web address of fusion at
> http://localhost/fusion/templates/mapserver/standard/index.html, the
> blank screen was viewed in my browser. The snapshot of my screen is
> attached in this email.
> Is there anybody can help me to solve this problem ? please
> regards
> Firdaus
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
_______________________________
Firdaus
Sekjen YKU
http://www.kemaslahatan-ummat.org
http://firdausadnan.wordpress.com
More information about the fusion-users
