IRIX build feedback
Randall Hopper hopper.randall at e...
Thu Aug 30 12:43:50 EDT 2001
Just a bit of feedback from building GDAL 1.1.5 on SGI IRIX.
If you Ctrl-C configure, it nukes the "core" source directory, thanks to
this line in configure:
trap 'rm -fr conftest* confdefs* core core.* *.core $ac_clean_files; exit 1' 1
2 15
Please change all the "cd" lines in the build makefiles so they fail if the
directory doesn't exist. Otherwise they generate an infinite build loop:
< (cd core; $(MAKE))
> (cd core && $(MAKE))
The BYTE_ORDER compile test in configure needs this code added to the
little test program:
#ifdef sgi
# include <sys/endian.h>
#endif
to successfully configure using gcc on IRIX. Note that configuring with IRIX
cc works fine without this mod.
I ran configure like this:
env CC="cc -n32 -O2" CXX="CC -n32 -O2" \
CPPFLAGS="-I/usr/local/include/cfitsio" \
LDFLAGS="-n32 -rpath /usr/local/lib32" \
configure --prefix=/usr/local --with-libz=internal \
--with-png=internal --with-libtiff=internal --with-libgeotiff=internal \
--with-libjpeg=internal --with-libgif=internal --with-python
however the build didn't include $CPPFLAGS on the $CC compilation command
lines as is typically done, so the fits code couldn't find it's headers.
IRIX doesn't define rindex in string.h (it's in strings.h). However,
the more common strrchr is defined in string.h. Perhaps gdal could use that
instead. Here's the patch:
frmts/fits/fitsdataset.cpp:
< if (rindex(newValue, '&') == newValue + strlen(newValue) - 1) {
> if (strrchr(newValue, '&') == newValue + strlen(newValue) - 1) {
LDFLAGS is not being propagated to the LD_SHARED setting in the build, so
the gdal library fails to build. And the apps built in apps/ fail to run
for the same reason (can't find their libraries because they didn't get the
RPATH seting).
Not fatal, but when linking libgdal.1.1.so, I get a bunch of
multiply-defined symbol link warnings because the build is linking in both
the .o files and library which contains them. Here are a few sample:
ld32: WARNING 15 : Multiply defined:(OGRRegisterAll) in
./ogr/ogrsf_frmts/gener\
ic/ogrregisterall.o and ./ogr/ogrsf_frmts/ogrsf_frmts.a(ogrregisterall.o) (2nd
definition ignored).
ld32: WARNING 15 : Multiply defined:(DDFModule::DDFModule(void)) in
./frmts/o/d\
dfmodule.o and ./ogr/ogrsf_frmts/ogrsf_frmts.a(ddfmodule.o) (2nd definition
ign\
ored).
Randall
__________________________________________________
Do You Yahoo!?
Get email alerts & NEW webcam video instant messaging with Yahoo! Messenger
http://im.yahoo.com
