[gdal-dev] Is there a driver to import USGS DEMs (non SDTS)?
Aleksey naumov at a...
Tue Nov 27 16:50:58 EST 2001
Frank,
Thank you for adding this driver, and so quickly too! After building PROJ.4
(GRASS only has a static version of it) I was able to examine USGS DEM
datasets with gdalinfo and import them in GRASS with r.in.gdal -- all works
well so far.
I have a few minor suggestions on PROJ.4, I'll send them to you directly so
that not to pollute this list.
Thanks again,
Aleksey
> Aleksey,
> I had started on a USGS DEM driver based on some VTP code a few months ago
> but never finished it. However, driven forward by your request I have
> completed it, and checked it in. It seems to work well, thanks for Ben
> Discoe's VTP code!
> If you want to use it, you will need to rebuild from CVS.
> Best regards,
