[Gdal-dev] ntf to postgres tables
nida Khan nida at webstar.co.uk
Wed Dec 18 09:20:39 EST 2002
Frank,
Thank you so much for your help, I really appreciate it :).
you r a star of this list!
kind Regards
Nida
xx
----- Original Message -----
To: <gdal-dev at remotesensing.org>
Sent: Tuesday, December 17, 2002 5:06 PM
Subject: Re: [Gdal-dev] ntf to postgres tables
> nida Khan wrote:
> > good idea! it works wonders! :).
> > I was able to import  all the files in the postgres, in that process I
found
> > a weired thing though.
> > First time when I import into postgres it works fine, after that I drop
the
> > table and asso. seq. and repeat the process, this time it fails with
this
> > error
> Nida,
> I believe the problem is that though you dropped the table, the table
still
> appeared in the geometry_columns metadata table and thus an attempt to add
it
> again with the same name failed.  If you read the SQL docs you will see
> a DropGeometryColumn() function or something similar you can invoke to
> clean a value out of the geometry_columns table.
> Instead of dropping the table yourself, you can use the "OVERWRITE=YES"
layer
> creation option, and ogr2ogr will take care of getting rid of all aspects
of
> the old layer itself.
> Best regard,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
