[Gdal-dev] Image Reprojection
Thu Apr 3 15:02:18 EST 2003
Matt Lynch wrote:
> I ran gdalinfo on out.tif and saw that I was missing gdal.dll.  I
> grabbed that off the gdall5a release.  Now I get the following - again
> it must be that I need to feed proj4 the specifics of a 10TM projection.
Matt,
I assume you mean you are missing "proj.dll"?  You can find more
recent versions at http://www.remotesensing.org/proj/ however, I would
have expected what is in the 1.1.5a GDAL binary release to be OK.
> C:\gdal>gdalwarp -t_srs "+proj=latlong +datum=WGS84" jeffpan2000_10m.tif
> out.tif
> ERROR 1: Can't find requested entry point: pj_strerrno
> ERROR 1: Failed to import coordinate system `'.
> :0...10...20...30...40...50...60...70...80...90...100 - done.
> When I run gdalinfo on out.tif now I get ...
What does it report about the source file?  If it can't report the
corners in lat/long properly then the source is the issue.
Best regards.
