[Gdal-dev] gdalwarp: bad output header?
Michael Tan mdtanxp at myrealbox.com
Mon Apr 14 14:55:49 EDT 2003
Hi Frank-
I got the latest version of Proj and the daily CVS build of gdal, and it
worked! I did find one glitch that you might want to know about. It turns
out that if the output file already exists, gdalwarp will sometimes
produces error messages and fail to do the projection.
Thanks!!
Michael
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Frank Warmerdam
Sent: Saturday, April 12, 2003 9:54 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] gdalwarp: bad output header?
Michael Tan wrote:
> Hello Frank-
> The files are from OpenEV_FW_154.zip
Michael,
OK, I am pretty sure this is related to a specific bug in the GeoTIFF
driver from around that time.  It is fixed in CVS now.  If you can easily
build from source, then grab the current source from CVS and rebuild.
Otherwise I will try to crank out a 1.5.5 release of the utilities in the
near future.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
