[Gdal-dev] MrSID format (+ GDAL doc page)
Aleksey Naumov naumov at acsu.buffalo.edu
Sat Aug 2 16:43:12 EDT 2003
Andrey,
On Friday 01 August 2003 03:53 pm, Andrey Kiselev wrote:
> Aleksey,
> On Fri, Aug 01, 2003 at 03:08:23PM -0400, Aleksey Naumov wrote:
> > Is there any way to read MrSID files without the DSDK from LizardTech?
> I'm afraid, there isn't other way to do this. GDAL works as a wrapper
> for DSDK.
Ok, thanks for explaining.
> Try to download their software again. Both Linux and Windows utilities
> from LizardTech works good enough for me for converting purposes. Linux
> one sometime crashes and works only for MrSID files version 1.x (yes,
> LizardTech has several backward incompatible versions of the format!),
> so you may consider using Windows viewer.
Downloading again does not help, tar still has problems with decoder/info
downloaded file ('Linux_sid.tar', 9.3M). The viewer works, but does not
export coordinates ('tiff' option does not write the world file, and there is
no 'geotiff' option).
Anyway, decoder works under Win with the -geotiff option, this is what I am
using at the moment...
> > 	- "gdal_utilities.html" page seems not provided with the package
> > 	(CVS),
> Are you sure? I have rebuilded all documantation with `make docs'
> command and all files seems to be written properly, including
> gdal_utilities.html.
Yes, I don't understand what's happening. I see 'gcore/gdal_utilities.dox' and
when doxygen runs I see:
Preprocessing /home/Geo/GDAL/gdal/gcore/gdal_utilities.dox...
Parsing file /home/Geo/GDAL/gdal/gcore/gdal_utilities.dox...
But in the end I do not have the 'gdal_utilities.html' file:
[aleksey at hap595 gdal]$ find . -name gdal_util*
./gcore/gdal_utilities.dox
[aleksey at hap595 gdal]$ ll html/gdal_util*
ls: html/gdal_util*: No such file or directory
No idea why... Well, it's not that important anyway.
Thanks for your help,
Aleksey
Aleksey Naumov
GIS Analyst
Center for Health and Social Research
Buffalo State College
