[Gdal-dev] gdal_merge.py question
Gillian Walter gillian.walter at atlantis-scientific.com
Mon Aug 18 12:38:06 EDT 2003
Do you have another version of python installed on your system?  If you
do, windows might be trying to use that version rather than OpenEV's.  I
seem to recall having a problem like that before on windows, but I think
I just ended up uninstalling the other version.  If the presence of
another version of python is what is causing the problem, the only thing
I can think of to try other than uninstalling the other version of
python is to make sure that openev's python21.dll is copied into
OpenEV/bin and OpenEV/pymod in case windows will look in the current
directory before system directories for library files.  You could also
try downloading a version of OpenEV that uses a version of python
consistent with yours.  I think Frank's latest build (OpenEV_FW_162.zip)
uses python 2.2.something.  You can find these builds at
ftp://ftp.remotesensing.org/gdal/openev/.
Gillian
Stephen H. Savage wrote:
>Greetings,
>   I'm still having difficulties getting gdal_merge to work.  I've installed
>the latest version of OpenEV.  After installing the OpenEV 1.6 software, the
>environment variables are set as follows:
>set OPENEV_HOME=C:\PROGRA~1\Atlantis\OPENEV~1.60
>set path=%OPENEV_HOME%\bin;%OPENEV_HOME%\python\Lib;%PATH%
>set PYTHONHOME=%OPENEV_HOME%\python
>set PYTHONPATH=%OPENEV_HOME%\pymod;%PYTHONHOME%\Numeric;%PYTHONHOME%\Lib
>I tried to run this command from a DOS prompt
>c:\Program Files\Atlantis\OpenEV 1.60pymod\gdal_merge.py -n 0 -o testout.tif
>c:\ImageFix\34e29n_36.tif c:\ImageFix\34e30n_36.tifpymod\gdal_merge.py -n 0 -o
>testout.tif c:\ImageFix\34e29n_36.tif c:\ImageFix\34e30n_36.tif
>It reports this in the DOS window:
>Traceback (most recent call last):
>   File "C:Program Files\Atlantis\OpenEV 1.60\pymod\gdal_merge.py", line 55,
>in ?
>	import gdal
>   File "C:Program Files\Atlantis\OpenEV 1.60\pymod\gdal_merge.py", line 156,
>in ?
>	import _gdal
>ImportError: Module use of pyton21.dll conflicts with this version of Python.
>I tried to register gdal11.dll by hand with RegSrvr.exe, but it couldn't do it.
>Any suggestions?
>Thanks,
>-Steve
>Quoting Gillian Walter <gillian.walter at atlantis-scientific.com>:
>>Hi,
>>You'll need to set some environment variables (PATH,PYTHONPATH,
>>PYTHONHOME,OPENEVHOME).  If you look at openev.bat in openev's bin
>>directory, you should see these settings.  I think gdal11.dll is in
>>OpenEV's bin directory, so adding the full path of the bin directory to
>>the PATH variable (and if that fails, to the PYTHONPATH variable) should
>>hopefully fix things.
>>-Gillian
>>>Greetings,
>>>I've recently installed the curreent version of OpenEV.  I'm trying to
>>execute
>>>the command "gdal_merge.py -n 0 -o out.tif in1.tif in2.tif" and I get
>>an error
>>>message that reads "The application has failed because gdal11.dll was
>>not
>>>found..."
>>>What do I need to do to make sure gdal utilities see all the .dlls and
>>the like?
>>>Thanks,
>>>-Steve
>>>Stephen H. Savage, Ph.D.
>>>Department of Anthropology
>>>Box 872402
>>>Arizona State University
>>>Tempe, AZ  85287-2402
>>>shsavage at asu.edu
>>>http://archaeology.asu.edu/Jordan/index.html
>>>_______________________________________________
>>>Gdal-dev mailing list
>>>Gdal-dev at remotesensing.org
>>>http://remotesensing.org/mailman/listinfo/gdal-dev
>Box 872402
>shsavage at asu.edu
>----- End forwarded message -----
>Box 872402
>shsavage at asu.edu
