[Gdal-dev] SAR_CEOS: possible memory leak ?
N. Farah nfarah at hotmail.com
Wed Dec 10 11:17:33 EST 2003
While reading a SARA_CEOS image the process went fine, but a memory dump
occurred in my debug session.
To try to isolate the problem, I tried to, only, open the image then close
it, the same behavior occurs. This suggests that a possible memory leak
might be in the Open(...) method.
I was using the "ottawa_patch.img" dataset from the remotesensing.org ftp
site.
Noureddine Farah
_________________________________________________________________
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
http://join.msn.com/?page=features/virus&pgmarket=en-ca&RU=http%3a%2f%2fjoin.msn.com%2f%3fpage%3dmisc%2fspecialoffers%26pgmarket%3den-ca
