[Gdal-dev] SAR_CEOS: possible memory leak ?
Wed Dec 10 13:04:14 EST 2003
N. Farah wrote:
> Hi,
> While reading a SARA_CEOS image the process went fine, but a memory dump
> occurred in my debug session.
> To try to isolate the problem, I tried to, only, open the image then
> close it, the same behavior occurs. This suggests that a possible memory
> leak might be in the Open(...) method.
> I was using the "ottawa_patch.img" dataset from the remotesensing.org
> ftp site.
Noureddine,
I tried running gdalinfo -mm under valgrind on the ottawa patch image, and
it didn't identify any illegitimate memory use on Linux.  I did find a few
minor memory leaks for which I have committed fixes, but these should not
explain a crash.
Could you try and dig into the problem from your end a bit more?
Best regards,
