[Gdal-dev] How to add a utility to GDal ?
Anand Madhavan anandm at ittc.ku.edu
Tue Feb 11 17:44:44 EST 2003
Hi GDal Users,
   I am using GDAl to translate images between formats. I would like to add
my own utility to GDal in addition to the already present ones, which would
use the APIs of GDAL. Is there a documentation as to how I should modify the
MakeFile, etc ... so that my utility compiles along with the GDal libraries
? Any help regarding this is highly appreciated.
Thank you
Anand Madhavan
