[Gdal-dev] Problem Unable to load PROJ.4
roni zanolli rzanolli at hotmail.com
Tue Feb 18 10:18:00 EST 2003
Hi All,
I installed gdal-1.1.8 and I'm using it with Virtual Terrain Project. My O.S
is linux suse 8.1 and when I tried to convert a projection coordinate from
nad27 to nad83 I get a error message
ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of
OGRCoordinateTransformation failed.
I installed proj-4.4.5 and the libproj.so is locate in /usr/local/lib and my
ldconfig is set up to look to this path.
Debugging the code I found that the file cplgetsymbol.cpp is using Dummy
implementation instead of Unix Implemnetation because HAVE_DLFCN_H was not
define when running configure prior to the instalation.
So I run configure again and figure out that it is not findind most of my
header files like
dlfcn.h, unistd.h, fcntl.h.
Can somebody help me with this problem?
Thank you,
                 Roni
_________________________________________________________________
MSN 8 with e-mail virus protection service: 2 months FREE*
http://join.msn.com/?page=features/virus
