[Gdal-dev] Save GeoTiff
Ayman Kamal kamal_jo at yahoo.com
Wed Mar 12 02:32:19 EST 2003
I used "gdal_translate" to convert a gray .bmp file to
a geotiff file. I opened this file using GDAL library,
and tried it in other viewers, it worked.
Now I tried to convert a colored .bmp files: 256,
24bit
Then I opened the resulting geotiff file in my
application using GDAL and tried the same using OpenEV
and it worked,
BUT:
I tried to open it using differnt GeoTiff viewers, one
of them showed it as a whole black and the other didnt
open it and complained with the message:
"65535: Sample out of range, max 3"
What is the problem? Is the problem that the images
arec colored or what?
__________________________________________________
Do you Yahoo!?
Yahoo! Web Hosting - establish your business online
http://webhosting.yahoo.com
