[Gdal-dev] Landsat 7 data
Andrey Kiselev dron at ak4719.spb.edu
Wed Mar 12 08:34:07 EST 2003
On Wed, Mar 12, 2003 at 02:21:15PM +0100, Horst Reinecke wrote:
> > > i trying to read FASTL7 data with grass5.0 (r.in.gdal) or gdalinfo. Both
> > > times i get the answer "ERROR 4: <filename> not recognised as supported
> > > fileformat". I using gdal-bibliothek 1.1.8. What wrong?
> > Probably you supply r.in.gdal with wrong file. You should read header
> > file, not the binary image itself.
> Thanks, but I took the headerfiles xxx_hpn.fst xxx_hfr.fst and xxx_htm.fst.
Send your header files to me, please.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
