[Gdal-dev] /MD on Windows, SDTS problem and fix
Thu May 22 15:15:09 EDT 2003
Ben Discoe wrote:
> Recently i've been hitting memory problems with OGR, so i wanted to switch
> to using /MD to build GDAL with MSVC.  In fact, i notice that this change
> was checked into nmake.opt recently as well - and it's a good move.
> However, switching to /MD caused a bug to pop up with using OGR to read
> certain SDTS files.  I have tracked the bug down, and found it has to do
> with using realloc() on a string that is precisely the length of its buffer,
> which can cause (depending on heap conditions) an unterminated string and
> subsequent crash.
> Here is the 1-line fix:
> RCS file: /cvsroot/osrs/gdal/frmts/iso8211/ddffielddefn.cpp,v
> diff -w -r1.9 ddffielddefn.cpp
> 456c456
> <                 if( (int) (strlen(pszExpandedContents) + strlen(pszDest))
>>                if( (int) (strlen(pszExpandedContents) + strlen(pszDest) +
> 1)
Ben,
I have committed this change.
Thanks Ben!
