R: [Gdal-dev] gdal in debian
Silke Reimer Silke.Reimer at intevation.de
Wed Nov 5 05:07:13 EST 2003
On Wed, Nov 05, 2003 at 10:54:19AM +0100, Amici Alessandro wrote:
> Silke,
> > with help from Alessandro Amici, Frank Warmerdam, Paul Baker and my
> > debian sponsor Jochen Friedrich I was able to get gdal into debian. If
> > you would like to know more about the status of the gdal package in
> > debian please have a look at
> > 	http://packages.qa.debian.org/g/gdal.html
> > If you experience any problems with the package please send a bug to
> > the debian bug tracker. I will then do my best to solve the problem.
> > Again many thanks to all those who helped me finish the package
> > especially Alessandro who mainly build the package.
> that's great!
> the road into sarge (the upcoming stable release of debian) is still
> long, but we still have a chance to make it.
> first problem: portability to all the debian architectures.
> Andrey, on arm and powerpc we get the following error into the hdf4 driver:
> make[3]: Entering directory `/build/buildd/gdal-1.2+cvs.031016/frmts/hdf4'
> /bin/sh ../../libtool --mode=compile g++ -I../../port -I../../gcore
> -I../../ogr -I/usr/include/hdf -Wall  -O2   -c -o ../o/hdf4dataset.o
> hdf4dataset.cpp
>  g++ -I../../port -I../../gcore -I../../ogr -I/usr/include/hdf -Wall -O2 -c
> hdf4dataset.cpp  -fPIC -DPIC -o ../o/.libs/hdf4dataset.o
> hdf4dataset.cpp: In member function `char**
>    HDF4Dataset::TranslateHDF4Attributes(long int, long int, char*, long int,
>    long int, char**)':
> hdf4dataset.cpp:763: error: invalid conversion from `int8*' to `const char*'
> hdf4dataset.cpp:766: error: invalid conversion from `int8*' to `const char*'
> make[3]: *** [../o/hdf4dataset.o] Error 1
> if you so wish i can file a bug report.
Yes, go ahead.
I won't have time to bother with this problem until Monday. But
surely I will need some help from somebody who is more familar with
arm and powerpc than me, so if you, Andrey have any suggestion this
would be great.
Cheers,
	Silke
Silke Reimer
Intevation GmbH                      http://intevation.de/
FreeGIS                                http://freegis.org/
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031105/f82946c1/attachment.bin
