[Gdal-dev] continued build problems..
Byron Amerson byronea at u.washington.edu
Fri Nov 7 13:24:43 EST 2003
Once again, thank you Frank.  I have been follwing your suggestions and
learning quite a bit which is great.
None the less gdal refuse to build on my mac.  It can't seem to find
Numeric for one thing -
Using a nightly snapshot from a few days ago, here is my config command:
sudo ./configure --with-local=/usr/local/include/python2.3/Numeric
--with-libz=internal --with-png=internal --with-libtiff=internal
--with-geotiff=internal --with-jpeg=internal --with-gif=internal
--with-pg=/usr/local/pgsql/bin/pg_config
and the last few lines of the resulting output:
checking where .py files should go...
/usr/local/lib/python2.3/site-packages
checking for python headers... found
checking definitions from Python makefile... done
checking for NumPy include files... missing
checking if local/include already standard... no, everything is ok
configure: creating ./config.status
config.status: creating GDALmake.opt
config.status: creating port/cpl_config.
below is the output from make:
g++ -Wl,-bind_at_load  -o .libs/_gdalmodule.so -bundle  .libs/gdal_wrap.o
.libs/numpydataset.o .libs/gdalnumeric.o  -L/usr/local/pgsql/lib
-L/usr/local/include/python2.3/Numeric/lib ../.libs/libgdal.dylib -lm -ldl
-lpq -L/usr/local/src/gdal/gdal-cvs-031104/.libs
ld: warning -L: directory name (/usr/local/include/python2.3/Numeric/lib)
does not exist
ld: Undefined symbols:
_PyArg_Parse
_PyArg_ParseTuple
_PyDict_New
_PyDict_Next
_PyDict_SetItem
_PyDict_Type
_PyErr_Clear
_PyErr_SetString
_PyEval_CallObjectWithKeywords
_PyExc_MemoryError
_PyExc_NameError
_PyExc_TypeError
_PyExc_ValueError
_PyFloat_AsDouble
_PyFloat_FromDouble
_PyInt_AsLong
_PyInt_FromLong
_PyInt_Type
_PyList_New
_PyList_SetItem
_PyList_Size
_PyList_Type
_PyModule_GetDict
_PyString_AsString
_PyString_FromString
_PyString_FromStringAndSize
_PyString_Type
_PyType_IsSubtype
_PyType_Type
_Py_BuildValue
_Py_InitModule4
__Py_NoneStruct
make[1]: *** [_gdalmodule.la] Error 1
make: *** [py-module] Error 2
evidently --with-local=/usr/local/include/python2.3/Numeric is not the
correct modifier as it seems that make is looking for shared libs in the
above directory.  I was just attempting to get gdal to see where the
Numeric headers lived.
Incidentally - I completely rebuilt python2.3.2 and postgresql7.4beta5
When I ran make for postgres it griped that libpython was not shared so it
could not build the PLPYTHON bits.  I don't know if this (python shared
libs) is relevant.
I don't know how to proceed. It would be great to b using GRASS about
now...
Byron Amerson
MS student
University of Washington
Department of Earth and Space Sciences
