[Gdal-dev] A change on gdal building dir?
Luis W. Sevilla sevilla_lui at gva.es
Mon Nov 17 09:21:04 EST 2003
Hi again,
    I'm trying to build OpenEV+gdal from sources.  After building and
installing (make; make install), when configuring OpenEV for building
I've got folowing error:
luisw at Aplicgraf1:/source/python/openev> ./configure
--with-gdal=/source/c/gdal
loading cache ./config.cache
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
Using requested GDAL_HOME of /source/c/gdal
configure: error: 'Unable to find /source/c/gdal/core directory, are you
sure a
regular GDAL build tree can be found at /source/c/gdal?'
There's a gcore directory under my GDAL build tree, but no core
directory at all. I's a change on gdal building dir or am I doing
something wrong ?
    Luis
