[Gdal-dev] GNU make build system update
Alessandro Amici alexamici at tiscali.it
Tue Sep 2 18:40:31 EDT 2003
oops! i just hit what might be a problem!
On Wednesday 03 September 2003 00:14, Alessandro Amici wrote:
> furthermore a 200k patch to aclocal.m4 is needed!
the aclocal.m4 patch appear to need autoconf 2.50+, but as far as i can say
gdal is still using autocon 2.13, so there are various alternatives:
- gdal can switch to autoconf 2.50+ (Frank?)
- i can look for an erlier version of libtool (i have 1.5.0a)
- i can try to port the aclocal.m4 to the 2.13
the libtool merge is already on held :(
cheers,
alessandro
