[Gdal-dev] GNU make build system update
Alessandro Amici alexamici at tiscali.it
Tue Sep 2 18:14:05 EDT 2003
Frank,
the build system is now close to the point i can start including (optional)
libtool support.
most of the changes i did up to now were intended to be generally useful
cleanups. there is still work that can be done, however:
gdal-1.1.9$ find . -name GNUmakefile -o -name GDALmake.opt | xargs wc
 2827  6507 58432 total
gdal-current$ find . -name GNUmakefile -o -name GDALmake.opt | xargs wc
 2290  5095 47873 total
now the libtool specific changes will stat going in.
first of all, in order to proceed with the libtool integration a few files
need to be added to the topdir, namely:
config.guess
config.sub
ltmain.sh
all files in the 100k+ range :(
furthermore a 200k patch to aclocal.m4 is needed!
all this stuff is distributed with the libtool package and it is intended to
make the build process independent on the version of libtool that people may
have installed.
it will take a bit of time before the alternative build will be fully
fuctional, but those who feel brave enough can try to add --with-libtool to
the configure command line to see how things are proceding ;)
for the others nothing should change.
cheers,
alessandro
