[Gdal-dev] Memory leak fixes in ogrfeaturesytle.cpp
Steve Brooks sbrooks2 at kc.rr.com
Sun Sep 28 00:38:06 EDT 2003
Frank,
  I ran across several memory leaks in ogrfeaturestyle.cpp
with a large input file and querying the feature style string I was
getting several thousand memory leaks.
The problem was in two places, first in CreateStyleToolFromStyleString
it was not calling CSLDestroy(papszToken);
Then in the destructors of OGRStyleTool subclasses they were
only calling CPLFree(m_pasStyleValue);
The problem with this is m_pasStyleValue is a vector like class of
several OGRStyleValue's.  Inside OGRStyleValue can be a pointer to a
heap allocated string in pszValue, which was the leak.
Below are the changes that fixed these leaks.
Thanks
Steve Brooks
$ diff clean/gdal/ogr/ogrfeaturestyle.cpp
modified/gdal/ogr/ogrfeaturestyle.cpp
432a433
>     OGRStyleTool *poStyleTool = NULL;
434,447c435,447
<     if (CSLCount(papszToken) <2)
<       return NULL;
<     if (EQUAL(papszToken[0],"PEN"))
<       return new OGRStylePen();
<     else if (EQUAL(papszToken[0],"BRUSH"))
<       return new OGRStyleBrush();
<     else if (EQUAL(papszToken[0],"SYMBOL"))
<       return new OGRStyleSymbol();
<     else if (EQUAL(papszToken[0],"LABEL"))
<       return new OGRStyleLabel();
<     else
<       return NULL;
>     if (CSLCount(papszToken) >= 2)
>          poStyleTool = new OGRStylePen();
>          poStyleTool = new OGRStyleBrush();
>          poStyleTool = new OGRStyleSymbol();
>          poStyleTool = new OGRStyleLabel();
>     return poStyleTool;
1394a1395,1402
>    for (int i = 0; i < OGRSTPenLast; i++)
>       if (m_pasStyleValue[i].pszValue != NULL)
>          CPLFree(m_pasStyleValue[i].pszValue);
>          m_pasStyleValue[i].pszValue = NULL;
1414a1423,1430
>    for (int i = 0; i < OGRSTBrushLast; i++)
1434a1451,1458
>    for (int i = 0; i < OGRSTSymbolLast; i++)
1455,1456c1479,1490
<     CPLFree(m_pasStyleValue);
>    if (m_pasStyleValue != NULL)
>       for (int i = 0; i < OGRSTLabelLast; i++)
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030927/5f514d5f/attachment.html
