[Gdal-dev] gdal on amd64 needs -fPIC?
Vincent Schut schut at sarvision.com
Thu Apr 1 04:49:37 EST 2004
On Tuesday 30 March 2004 15:27, Alessandro Amici wrote:
> Vincent,
> > > I just tried to compile gdal on my new amd64.
> luck you ;)
<grin>
> > More info:
> > both netcdf/hdf and gdal need -fPIC. I tried compiling gdal with -fPIC
> > while having hdf4 compiled without, and that didn't work out.
> > Might be that gdal when compiled without hdf4 support doesn't need -fPIC,
> > but as I need hdf4 support I didn't try that yet.
> do you use the standard (libtool) build or the old style one
> (--without-libtool)?
> in both cases it would be helpfull to have the configure command line that
> you use and a snipped of both compile and link commands.
> and the actual error message, obviously ;) !
Well I just took the effort to create a really really informative message for
you with make outputs and configure options and stuff like that, then in the
end the error doesn't show anymore. I did a cvs update before that. Did you
change things in cvs regarding -fPIC? Or was it something else (which I'll
have to find out then) that caused the error here?
Note that all this is with a HDF4 lib compiled *with* -fPIC.
Cheers,
Vincent.
> cheers,
> alessandro
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
 Vincent Schut
 SarVision B.V.
 Wageningen, The Netherlands
 www.sarvision.com
