[Gdal-dev] gdal on amd64 needs -fPIC?
Alessandro Amici alexamici at fastwebnet.it
Sun Apr 4 13:42:30 EDT 2004
Vincent,
sorry for the long delay.
On Thursday 01 April 2004 11:49, Vincent Schut wrote:
> Well I just took the effort to create a really really informative message
> for you with make outputs and configure options and stuff like that, then
> in the end the error doesn't show anymore.
lucky me ;)
> I did a cvs update before that.
> Did you change things in cvs regarding -fPIC? Or was it something else
> (which I'll have to find out then) that caused the error here?
no change from me.
if you need to further investigate the problem the only hint that i can give
you is that if you change the reconfigure gdal without a "make clean", stale
files can pollute the build. but i don't see how this can give the error you
reported.
> Note that all this is with a HDF4 lib compiled *with* -fPIC.
do you mean libmfhdf.so of the hdf driver inside gdal?
BTW: which distribution do you use?
really i can't imagine the x86-64 binutils being much different from x86 ones.
cheers,
alessandro
