[Gdal-dev] Center of polygon
Chapman, Martin MChapman at sanz.com
Tue Apr 6 12:27:18 EDT 2004
Frank,
What is GEOS? Can you point me to the homepage?
Martin
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tuesday, April 06, 2004 10:19 AM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Center of polygon
Clay, Bruce wrote:
> Daniel:
>   Thanks for the tip.  All I had to do is include the mitab_geometry.h
> file and the method did what I needed.
> Frank:  Several of the methods in this file seem to be quite generic.
> Could / should they be moved to the public ORG API.  So far I have
> only used OGRPolygonLabelPoint on polygons but I will be trying it on
> polylines this afternoon.
Bruce,
You are right that some of these methods could/should sensibly be moved
up to the OGRGeometry classes.  However, I have been hesitant to start
implementing and document custom OGR implementations of these sorts of
utility geometry functions when I anticipate integration with GEOS to
fill most of this capability at some point.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
