[Gdal-dev] Center of polygon
Tue Apr 6 13:06:42 EDT 2004
Chapman, Martin wrote:
> Frank,
> What is GEOS? Can you point me to the homepage?
Martin,
Is it is a C/C++ port of the Java Topology Suite.  It can be found at:
   http://geos.refractions.net/
It is an opengis simple features geometry based geometry engine.   It is
already used by PostGIS and since it shares a geometry model (though not the
actual object instance format) with OGR I think it should be easy to
integrate it to implement a variety of complex geometry operations for OGR.
Doing so is on my long term "todo" list.
Best regards,
