[Gdal-dev] Several questions
Tue Apr 13 19:22:39 EDT 2004
Romano J M Silva wrote:
> What is this caching limit?
Romano,
The default caching limit is currently 10MB but was 5MB up until
recently.  It can be controlled by various means, including the
GDAL_CACHE_MAX environment variable (set it to a cache size in bytes).
> I am commonly loading small window of data in a scanline mode. Is it
> possible to  "create" a tiled GeoTiff?
It is possible to create a tiled GeoTIFF.  The following is an example
of using gdal_translate to convert an input file into a tiled GeoTIFF
image.
gdal_translate -of GTiff -co TILED=YES in.tif out.tif
> How do I retrieve an overview to get its bands?
The GDALRasterBand::GetOverview() method can be used to fetch overviews
of a given band.  The GetOverviewCount() method returns the number of overviews
available.  There are C and Python analogs of course.
Best regards,
