[Gdal-dev] Python Module Build
Alessandro Amici alexamici at fastwebnet.it
Thu Apr 15 04:02:18 EDT 2004
Sean,
On Thursday 15 April 2004 04:32, Sean Fulton wrote:
> I've found that running the above command with "-framework Python"
> fixes this error, however, I can't find how to add "-framework Python"
> to that build command through the make or autoconf files.
> The configure log shows a PYTHON_LINK variable whose value contains
> "-framework ${PYTHONFRAMEWORK}" but it doesn't seem to be used
> anywhere.
> How do I pass "-framework Python" to the build command?
ok, finally i understand what is going on on MacOS X. i'll try to fix the
configure/make system ASAP. it is not strightforward, but it can be done ;).
> Also, is there a way to specify more than one location for Python
> headers and libs without mucking about in the configure script? Setting
> the PYTHON_INCLUDE environment variable seems to have no effect on
> configure.
i'll have a look at that also. in the mean time: the correct name for the
variable is PYTHON_INCLUDES, can that be the problem?
thanks very much for your report!
alessandro
