[Gdal-dev] Python Module Build
Alessandro Amici alexamici at fastwebnet.it
Thu Apr 15 17:53:07 EDT 2004
On Thursday 15 April 2004 10:02, Alessandro Amici wrote:
> ok, finally i understand what is going on on MacOS X. i'll try to fix the
> configure/make system ASAP. it is not strightforward, but it can be done
mmm, looks like things are harder than i thought along this route :(. i
couldn't beat the python build into submission, yet.
however, this is what i wrote in january when the macosx link problem was
reported for the first time:
> the build of the gdal python module has always been fragile, and it has
> became a real hack since the libtool transition (my fault, admittedly).
> IMHO the  only hope to get out of the current mess is to use the distutils
> infrastructure, that hopefully will take care of the OSX problem as well.
> so i refreshed what looked like an abandoned setup.py in the top directory.
> current gdal cvs builds and installs fine on linux with:
> $ ./configure <...> --without-python
> $ make
> $ python setup.py build
> $ python setup.py install
it still works on linux. could you test if it works on MacOS X as well?
