[Gdal-dev] Python Module Build
    Sean Fulton
    fulton at cmu.edu
    Mon Apr 19 23:35:42 EDT 2004
On Apr 15, 2004, at 5:53 PM, Alessandro Amici wrote:
> Sean,
> On Thursday 15 April 2004 10:02, Alessandro Amici wrote:
>> ok, finally i understand what is going on on MacOS X. i'll try to fix
>> the
>> configure/make system ASAP. it is not strightforward, but it can be
>> done
> mmm, looks like things are harder than i thought along this route :(. i
> couldn't beat the python build into submission, yet.
> however, this is what i wrote in january when the macosx link problem
> was
> reported for the first time:
>> the build of the gdal python module has always been fragile, and it
>> has
>> became a real hack since the libtool transition (my fault,
>> admittedly).
>> IMHO the  only hope to get out of the current mess is to use the
>> distutils
>> infrastructure, that hopefully will take care of the OSX problem as
>> well.
>> so i refreshed what looked like an abandoned setup.py in the top
>> directory.
>> current gdal cvs builds and installs fine on linux with:
>> $ ./configure <...> --without-python
>> $ make
>> $ python setup.py build
>> $ python setup.py install
> it still works on linux. could you test if it works on MacOS X as well?
Alessandro,
That didn't work (a bit of output is below). It looks like it's not
finding the gdal header files. Is there anyway to get tell it where
they are? I'm sorry, I don't know much about python so I'm not much
help.
	Sean
pymod/gdal_wrap.c:4587: error: parse error before "_arg0"
pymod/gdal_wrap.c:4589: error: `GDALColorEntry' undeclared (first use
in this function)
pymod/gdal_wrap.c:4589: error: `_arg2' undeclared (first use in this
function)
pymod/gdal_wrap.c:4597: error: `_arg0' undeclared (first use in this
function)
pymod/gdal_wrap.c:4610: warning: implicit declaration of function
`GDALGetColorEntryAsRGB'
pymod/gdal_wrap.c: In function `_wrap_GDALSetColorEntry':
pymod/gdal_wrap.c:4617: error: `GDALColorTableH' undeclared (first use
in this function)
pymod/gdal_wrap.c:4617: error: parse error before "_arg0"
pymod/gdal_wrap.c:4619: error: `GDALColorEntry' undeclared (first use
in this function)
pymod/gdal_wrap.c:4619: error: `_arg2' undeclared (first use in this
function)
pymod/gdal_wrap.c:4627: error: `_arg0' undeclared (first use in this
function)
pymod/gdal_wrap.c:4640: warning: implicit declaration of function
`GDALSetColorEntry'
pymod/gdal_wrap.c: In function `_wrap_GDALSetCacheMax':
pymod/gdal_wrap.c:4653: warning: implicit declaration of function
`GDALSetCacheMax'
pymod/gdal_wrap.c: In function `_wrap_GDALGetCacheMax':
pymod/gdal_wrap.c:4666: warning: implicit declaration of function
`GDALGetCacheMax'
pymod/gdal_wrap.c: In function `_wrap_GDALGetCacheUsed':
pymod/gdal_wrap.c:4678: warning: implicit declaration of function
`GDALGetCacheUsed'
pymod/gdal_wrap.c: In function `_wrap_GDALFlushCacheBlock':
pymod/gdal_wrap.c:4690: warning: implicit declaration of function
`GDALFlushCacheBlock'
pymod/gdal_wrap.c: In function `_wrap_GDALChecksumImage':
pymod/gdal_wrap.c:4698: error: `GDALRasterBandH' undeclared (first use
in this function)
pymod/gdal_wrap.c:4698: error: parse error before "_arg0"
pymod/gdal_wrap.c:4709: error: `_arg0' undeclared (first use in this
function)
pymod/gdal_wrap.c: At top level:
pymod/gdal_wrap.c:10815: warning: function declaration isn't a prototype
pymod/gdal_wrap.c:193: warning: `SWIG_addvarlink' defined but not used
error: command 'gcc' failed with exit status 1
