[Gdal-dev] Help: JPEG compressed TIFF cannot be used with GDAL
Eric Dönges Eric.Doenges at nadie.lpr.e-technik.tu-muenchen.de
Fri Apr 23 03:16:28 EDT 2004
Am 23.04.2004 um 05:30 schrieb xqcheng:
> Hi,
>   I have some images which cannot open with GDAL, Can I mail it in CD
> to you?
>   Then you can check it.
>   Thanks
> CXQ
Does the libtiff you are using have JPEG compression enabled ? While
GDAL seems to
do this if you use the internal libtiff stuff (and have JPEGs enabled
for GDAL), I
think standalone libtiff usually does not have it enabled by default.
Eric
